4 terminal voltage regulator
The parts guy at the local store only had a 4 terminal regulator that he gave to me real cheap for my 820 (pony start so its 6 volt) but I have a 3 terminal on it now. Can I use the 4 terminal and is so, do I wire it the same or different? Thanks for the help!
You can use a 3 in place of a 4 or 4 in place of a 3 with minor wiring changes.
If its a 4 you can ignore the 4th L terminal and leave the loads fed off the ammeter or transfer loads down to the VR's L terminal
John T
