TractorLinks.com
Show Parts for Model:
Re: john deere dtlx 67 carburater
machinery-man
06-10-2013 08:43:56
Those B carbs are slobbery anyway...the butterfly clearance will not hurt the power up...I can"t recall if the 67 is the all fuel...if it is it has the bypass and they are really slobbery....those the butterfly will not shut down, the gas models unless the pin has been bent you should have the safety shut down feature...on those the idle ports have to be clean..secret passages and all....it still should idle down if the other is clean and you should be able to install a new butterfly and make it block off...I always took a brake hone and lightly clean up the bore...most of these tractors will by nature foul out #2 if you run on limited basis....
