John Deere clutch pulley.
Anonymous-0
I have a 1952 A with a slight problem. The previous owner did god knows what to the original clutch pulley. It looks like the drive gear on spun somehow so he ended up drilling 8 holes around the gap between the gear and the clutch pulley end housing. He then drove rods into the holes and welded them. As you can guess, they didn"t work exactly. The gear walks back and forth making some noises and let the gear walk around a bit. Anyways, what all year clutch pulley assemblies would interchange with the late styled A?
You can look up and compare the part numbers on the Deere parts website. That's about all the help I can give you. Jim
