John Deere 1360
samn40
Be careful out there, this is the result of lifting a length of electic pole stay wire that someone had kindly dumped in my silage field. The second disc was out of timing so it needed a new gear also and I also needed 3 idler/intermediate gears and two days downtime getting it all dismantled and washed out. Rust was a real problem, grass is really corrosive! In case you are not familiar with the 1360, it is the same as a Kuhn with a Kuhn cutterbed.
Sam
Sam, be extra careful to get all the bits and pieces out of everything before re=assembly. One bit and you will be back in it in about 8 hours or less. Would also replace any rough bearings!
Roger
