Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: Moving wheels in on an A John Deere
Carlyle Hoffman
06-09-2013 13:30:00
Using 2 threaded rods with screw on eye,items used like in utility pole construction, couple flat washers and nuts, by the way ,5/8s" rod thru both wheels and a regular size cable hoist spanning across the floor plate and every time you tighten the hoist, cause you are tending to pull off center bump the cast wheel with a block of wood and you should be in buss. PS: Assuming the wheel is free to move first helps. Put the rods thru the SPLIT HOLES in that 6 bolt pattern that attaches the HUB to the CAST WHEEL.
