Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: JD Model H blown head gasket?
buck eye al
06-06-2013 14:34:16
When the drive train is locked up for whatever reason as long as it is "forward" of the differential they will do exactly as you describe. If you're pulling it forward, which ever wheel has the most traction keeps going forward but the one with less traction rotates backward. If you put the tractor in gear & jack it up so that BOTH rear wheels are off of the ground and roll either wheel forward the other will go backward. This is the differential's action working as it should.
D-
06-07-2013 16:04:30
 Re: JD Model H blown head gasket? in reply to buck eye al, 06-06-2013 14:34:16
Anytime you pull a tractor in too low a gear or engine locked, one wheel will turn backward. Remember when you were a young hotrodder? When you got on it the right wheel would spin. If you were in reverse the left one would spin. Now if the tractor is heavy enough you probably have a bent rod.
