Cool Gard II
JD Farmer
What's in this stuff to make it chalk white while its leaking? I am having trouble figuring this one out...driving me nuts...tried 2 hose clamps, must be a cracked piece of plastic? Going for parts today. Only leaks enough to make a mess, after 4 days in the fields it's still not below add mark.
I replaced some coolant hoses and gaskets and the coolant, then this problem came along. So I messed up where...
I think it's a chemical reaction between the rust inhibiting chemicals in the coolant and all the rust in the cooling system, I had the same problem when I filled my B up with it. flushed all kinds of crap into the drain plug too.
(quoted from post at 08:27:40 06/06/13)
I THINK that termostat housing updates to a different style that leaks less, Bob
Bob
You're correct(note part sub #)
R70736 Cover 1 - 792265 X X (ORD R97876, R97877, (2 ) 19H2633, (2) 24M7106)
