TractorLinks.com
Show Parts for Model:
Re: Our John Deere B's will not run.
Jethro Lilley
06-06-2013 09:10:35
You have to drain the fuel tanks on your B's, so do this... get an old 100% cotton flannel shirt with no holes. Must be flannel and must be 100% cotton. Drape the shirt over a clean bucket and drain the fuel through the shirt into the bucket. If it has water in it then the gas will end up in the bucket and the water will end up in the shirt. Don't ask me why, but the gas goes through the flannel and the water will not. End result is good gas with no water.
Spitfiremk14
06-06-2013 09:17:25
 Re: Our John Deere B's will not run. in reply to Jethro Lilley, 06-06-2013 09:10:35
its not the gas. The 1952 started doing this quite a while ago and we have been trying to fix it for a while so different gas has been used. We dont use ethinol in the tractors at all.
oros35
06-06-2013 10:18:20
 Re: Our John Deere B's will not run. in reply to Spitfiremk14, 06-06-2013 09:17:25
Try plugged fuel line, or plugged intake to the fuel bowl. I've had flakes of rust intermittantly block flow and act as you say.
Spitfiremk14
06-06-2013 13:55:59
 Re: Our John Deere B's will not run. in reply to oros35, 06-06-2013 10:18:20
Cheked blocked fuel lines, we did that first.
Spitfiremk14
06-06-2013 09:28:12
The 1949 started doing this just last week so they did not start doing this at the same time. The symptoms are exactly the same though. In fact the only diference I know of is that the 1949 has a compression of about 100psi while the 1952 is about 50-55. I seems like it probably is somthing sort of simple but we cant find anything wrong.
