Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: Rear Axles
Brad Ferries
06-05-2013 20:53:06
On my model the FELTS are the seals.
Thanks for the info on the Axel Nuts.
06-06-2013 20:35:40
 Re: Rear Axles in reply to Brad Ferries, 06-05-2013 20:53:06
NO, the felts are NOT the seals. Seals are inside, behind inner bearing, which is directly behind the bullgear which is what said nut tightens against. Felts are only to keep dirt from entering the outer bearing. They are porous & therefore CANNOT seal oil in.
Pete in MD
06-06-2013 12:32:53
I agree with Mike M.
Every B, unstyled and styled, used an oil seal. They're located just outboard of the inner bearing cup. With the axle removed you can drive out the seal by using a hammer and a long steel rod inserted from the outer end of the axle. The bearing cup can be left in place when you knock out the seal.
The felts are there only to keep dust and grit out of the outer bearing assembly.
Mike M
06-06-2013 10:20:05
You say a Model B and the felts are the seals ????
Never seen that before. They always have a lip type oil seal on the inner side of the housing and a felt at the outer end.
