2020 JD oil leaking out of case at the lift arms??
XL cid A
Does anyone no if you can remove the load control shaft
without removing lift cover and the rest of the load control
system? I've got the o rings and the Teflon bushings but can I
just drive the shaft out and put them in or does it all have to
come? Thanks for the help!
Yes L/D control shaft can be removed & seals replaced without R&R of RS housing. Drain hyd oil and put L/D lever in "D". Shim all side play out of shaft & draft links upon reassembly.
Thanks for the info. The shop manual didn't say if you could or
not it just started off by taking the lift off and working its way
down.
