1010 Pto slipping
Anonymous-0
I have a 1010 with Independent PTO
when mowing, the mower will start slipping ,then let set for second then it will pick back up and mow for a little more then do it again is there an adjustment on the plates that need to be done ?
Powershaft clutch should be adjustable at clevis(parts key #11) if I picked the correct linkage. What your tractors SN?
