4430 tractor clutch issue
hnorrish
New User
My 4430 the clutch seemes to be slipping under load it is also hard to get int gear at times is this a big problem?
They are not bad to change out but you will need some one with the set-up tool to adjust it.
You can check the pressure, like Jim said it should be around 165psi,,But from what i see going through here you most likely need the clutch serviced, new plates, operating seals and re-set..
