Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: 4230 knocking steering column
greenmachine
05-10-2013 15:24:06
Parts look cheap, I will have to look in my manual to see how big of a job it is.. Anyone have any tips on doing this job? Thanks!
Tim S
05-10-2013 15:52:03
 Re: 4230 knocking steering column in reply to greenmachine, 05-10-2013 15:24:06
Yours will most likely have the old style valve, they are ornery to get out and will need a set up tool to calibrate it,and some one familiar with it. I have a way of bench testing them here,,But I'm in Central Ohio.
greenmachine
05-10-2013 15:54:40
 Re: 4230 knocking steering column in reply to Tim S, 05-10-2013 15:52:03
Tim so you think its in the steering motor and not down at the steering piston? I should just rebuild both and be done with it.. I know my luck, do one and the other will need repair soon after..
Tim S
05-10-2013 16:10:11
 Re: 4230 knocking steering column in reply to greenmachine, 05-10-2013 15:54:40
Well if it's chattering at the dash I'm thinking you have some thing going on there, and worn o-rings in the valve will also cause it to "wander" on the road..
Tx Jim
05-11-2013 04:32:01
 Re: 4230 knocking steering column in reply to Tim S, 05-10-2013 16:10:11
JD started metering valve steering on a 4230 at SN 008840 so a 1973 could be either type steering.
Serial Number List for JD: Model 4230
This post was edited by Tx Jim at 04:33:09 05/11/13.
greenmachine
05-11-2013 10:00:46
 Re: 4230 knocking steering column in reply to Tx Jim, 05-11-2013 04:32:01
Its prior to 8000 serial number..
Tx Jim
05-11-2013 10:16:26
 Re: 4230 knocking steering column in reply to greenmachine, 05-11-2013 10:00:46
Then your tractor will have the old style steering valve that must be adjusted.
Copyright © 1997-2015 Yesterday's Tractor Co.
