TractorLinks.com
Show Parts for Model:
Re: John Deere 2440 Not starting
farm mechanic
05-08-2013 16:48:36
I have relocated the ground cable from a rusty spot to a bolt on the engine block, this didn't solve the problem, The starter was just rebuilt and the shop the rebuilt it said that it was bad. Would this also cause the hydraulics to chatter?
Tx Jim
05-09-2013 04:46:06
 Re: John Deere 2440 Not starting in reply to farm mechanic, 05-08-2013 16:48:36
Chattering hyd's could be a number of things and I'll list some of them.
plugged hyd sump screen
plugged hyd filter
faulty hyd filter relief valve
worn stroke control valve
broken/leaking supply tube to ind pto(if equipped)
broken/leaking supply tube to hyd hi-lo(if equipped)
worn trans pump
leaking rockshaft control valves
faulty inlet/outlet valves in frt hyd pump
possible faulty loader control valve &/or plumbing
