TractorLinks.com
Show Parts for Model:
Re: CYCLONE A HEAD
Mike n Mo
05-06-2013 17:42:42
You might need the shorter head studs, as the late head is 1/4" thinner than the early head, and may have a problem with being able to back off the rocker arm adjuster's enough. If that comes up, you can shim under the rocker stands. It will give you a nice increase in the compression ratio. Depending on the pistons that are there, you might have to run higher octane fuel. Listen for detonation/pinging under full load as the telltale. Mike
