TractorLinks.com
Show Parts for Model:
Re: 4020 and hydraulic motor use
JMS/.MN
05-06-2013 15:45:02
There certainly are when it comes to running sprayer pumps..........you don"t want to use one kind on the other kind of system. Check out Hypro, for one.
buickanddeere
05-06-2013 16:49:55
 Re: 4020 and hydraulic motor use in reply to JMS/.MN, 05-06-2013 15:45:02
Wrong, the valves are different not the motors.
If the return line was incorrectly routed back direct to sump on a closed center Deere. The front pump will take a beating and fail from cavitation. Don"t blame the tractor for misuse.
JMS/.MN
05-06-2013 22:11:20
 Re: 4020 and hydraulic motor use in reply to buickanddeere, 05-06-2013 16:49:55
Then why does Hypro have one hyd motor for open center systems, and another for closed center? The motors are not the same. I had to switch motors on a pump that was on an IH, to use it on a JD.
David G
05-06-2013 20:01:44
B&D, good to hear from you again.
Why is it that the motor gets super hot when run on 4020, but cool when run on tractor with OC hydraulics?
Tx Jim
05-07-2013 04:07:45
 Re: 4020 and hydraulic motor use in reply to David G, 05-06-2013 20:01:44
I thought orbit motors created heat on both type hyd systems because of pumping oil through an orifice. The reason closed center hyd oil gets hot is because operating an orbit motor is very similar to an internal high pressure leak. An internal leak on CC hyd system always causes the oil to heat.
