TractorLinks.com
Show Parts for Model:
Re: Fuel Shutoff John Deere 60
Deereseason48
05-06-2013 13:37:15
Tim S,
Where you able to use the same fuel line to the carb? Did you just make a oil line to go from the motor to the gauge? The reason I am leaning on going to manual valve is due to fact this tractor could sit for long periods of time and I don't want to worry about things going wrong.
Tim S
05-06-2013 13:48:29
 Re: Fuel Shutoff John Deere 60 in reply to Deereseason48, 05-06-2013 13:37:15
Yes you can flex the existing line enough to re-use your original fuel line,remove the fitting from the original bowl and screw it into the ball valve and use a short nipple to match the ball valve up to the new bowl, the threads in the fuel tank are 3/8" TSC has a sediment bowl that works well, I got the ball valve from Carr Supply, they were bit hard to find and I can send you one if you can"t find one around there, the nice thing about the ball valve is a quarter turn and it"s off nice and smooth, those Tee handles on the sediment bowl are hard on your fingers and they tend to drip a lot the more you use them..
