TractorLinks.com
Show Parts for Model:
Re: 4020 and hydraulic motor use
Mike Aylward
05-06-2013 10:15:22
A 4020 should turn that just fine. Depending on how big your motor is you may need a flow control valve to regulate the speed. If you try to do this on the SCV of the tractor you will create heat. When the flow is restricted on a hydraulic motor is when heat builds. Odds are you won't be using the motor for over an hour at a time (such as filling a semi) so the long term heat buildup shouldn't be too bad. Set your tractor SCV to "wide open" and then regulate the motor speed with a flow control valve. Should work just fine. Odds are the reason the newer tractor didn't turn the motor is because of a flow sensing system of some kind. Mike
