lady bug
New User
HAS ANY BODY USED HYD FLUID OTHER THAN JOHN DEERE IN NEW GEN TRACTORS .JOHN DEERE HAS A SPECIAL OIL ADDITIVE TO HELP WITH BRAKE CHATTER.
Yes there are some fluids that are compatible with the Deere wet brakes and clutches, BP offers one that a lot of farmers around here use with good results, but be sure before you go to change the wrong fluid will eat the brake pads up...Deere don't make the oil, that is a fact...
I have seen this happen first hand. I can't remember if it was Cen-Pe-Co or Shaeffer's that did this but it happened in just a couple of days. I was working in the Deere dealer's shop and put new brakes in a 4430. Hy-Gard was naturally put back in the tractor. The owner had one of these kinds of oil and topped it off with it. Two days later "my brakes are making noise". Took one axle housing off and the brake pads were GONE. Mike
Ooh yes the wrong fluid is death on them, I preach Deere fluid all the time to help eliminate confusion, that's all I use here in my shop. My Bros. have been using a BP fluid for the last 18 years and have had no problems with it in 4020's/4440's and 4960's,in high hour usage,I can't remember the fluid name and number right now...
I bought a new tractor in '07. The owners manual mentioned a special type of universal fluid and said that if you didn't use it you could expect problems. Since I still had 15 gallons of new "old style" fluid just sitting around, I got on the www to find out if and what was the difference in new and old.
Well there is and other than additional/different additives, it is a synthetic blend oil where the other was straight parafin based.
TSC has this new oil labeled as "Premium" UTF and it has some die in it. I remember Orange being the color of the dye to identify the new oil, but not sure. Read the label on it and the old type oil and you will know the difference.
If I had a JD and a JD dealer was close I would use that. But I don't have a JD and my dealer is not close so I look elsewhere.
I bought some synthetic UTF from Amisol for a DR lawn tractor/mower ZT hydraulic sump. When I bought the mower I had no idea as to how long the fluid would last and all. It sat on the shelf.
My tractor is 4wd and being new it has taken awhile for the 4wd shifter to go into gear easily....wear in. Some time ago, before I discovered the TSC oil, I was checking fluids and noticed my front axle sump which holds 2.5 gallons was low. I wound up putting 2 pints of Amisol in it to put it at the full mark. I didn't have any leaks and it's a sealed system so I guess the factory fill and the dipstick readings were two different things.
To my unexpected surprise, it wasn't long till the engagement was smooth as silk. I was impressed. Now what part of the oil caused that? I don't know but I do know that the lube properties of it exceeded the OEM oil and it is the newer kind of oil. Just an interesting (to me) occurrence.
Enough blabbing.
Mark
For a while the BP trans. oil looked "milky" when new, and even worse as it was used, I didn't like the looks at all, the newer version looks more like the Deere oil. It would be a great idea if they did color code it universally...it would save a lot of confusion...
