TractorLinks.com
Show Parts for Model:
Re: 2030 3 point
Tx Jim
05-04-2013 09:50:58
Sounds as if pressure control valve on RH side by hyd filter is faulty.Where are you taking the pressure reading? Checking both trans & frt hyd pump with a flowrater would be nice. Have you tried operating 3 pt with the hyd hi-lo in both speeds? does your tractor have hyd ind pto?
MSD
05-04-2013 12:23:02
 Re: 2030 3 point in reply to Tx Jim, 05-04-2013 09:50:58
I checked the pressure by disconnecting the line to the steering column. It pops right up when the 3 pt quits moving. I haven't tried it with the HI-LO in different spots that I know of. It could have been in either position when I did. No independent pto.
Tx Jim
05-04-2013 13:05:02
 Re: 2030 3 point in reply to MSD, 05-04-2013 12:23:02
It still appears that pressure(priority) valve isn't doing it's job of giving priority pressure to steering. What was stand-by pressure before raising 3 pt?
This post was edited by Tx Jim at 13:06:08 05/04/13.
MSD
05-04-2013 17:36:47
 Re: 2030 3 point in reply to Tx Jim, 05-04-2013 13:05:02
I believe it was 2200 or 2300 psi.
Tx Jim
05-05-2013 04:34:08
 Re: 2030 3 point in reply to MSD, 05-04-2013 17:36:47
I'd suggest to check pressure control valve.
