JD B Steering column bearings
Jim Skala
New User
How do I find a pair of JD part number B786R bearings that go on each side of the worm gear at the end of the steering column?
Since I don't know how to edit my post, I will use reply, instead.
I found a different part number for those bearings: JD7396R
I still need a pair of them...
I found a guy on EBay that had a bunch. Do a search with your part number. I don't know if they're still available or not.
Still available from John Deere about $20 each, when looking them up drop off the "R" on the end of the part number. That pretty much applies to all JD bearing numbers.
