TractorLinks.com
Show Parts for Model:
Re: JD A spitting back through carb
bill finn
05-03-2013 20:53:57
apply air pressure to cylinders through the plug holes, make sure valves are closed(easier to just close the vales by backing off adjustment screws). The piston will move to the bottom of the stroke, then listen for air escaping thru intake or exhaust or breather. If air is coming thru carb, you have a leaking intake valve.If its a simple miss fire, some plugs work better then others. Someone with more experience than me could probably make a suggestion.I would also pay close attention to float height, needle and seat and fuel quality.and last spray carb cleaner around intake manifold and listen for rpm changes.
Good luck
teddy52food
05-04-2013 07:44:20
 Re: JD A spitting back through carb in reply to bill finn, 05-03-2013 20:53:57
You have to keep the piston at TDC. if it goes to the bottom, the exaust valve will be open.
