Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: fuel tank sender wires 4020
Cliff Nelson
05-03-2013 18:28:41
You don't need to drill a new hole. Just use any one of the existing bolts in the area such as radiator brace, frame plate bolt, etc.
Nylon4020
05-03-2013 19:32:14
 Re: fuel tank sender wires 4020 in reply to Cliff Nelson, 05-03-2013 18:28:41
Cliff,
Think I could use the tank strap bolt? Solder small circle connector to one end for sender screw and then 8 inches of wire with larger circle connector soldered to other end. Put one nut on strap bolt, slip on wire connector and then tighten down another nut to sandwich it on that bolt.
Cliff Nelson
05-03-2013 20:53:45
 Re: fuel tank sender wires 4020 in reply to Nylon4020, 05-03-2013 19:32:14
That might be sketchy with a poly tank. There is a clamp on the steering pipes above the hood line (between the H and N on the nameplate). This was used as a ground point on the console models. Just be sure the clamp is tight on the radiator rod.
Nylon4020
05-04-2013 16:22:28
 Re: fuel tank sender wires 4020 in reply to Cliff Nelson, 05-03-2013 20:53:45
Appreciated!
Thx Cliff
