2955 no pto, no steering, no lift
2955guy
New User
2955 started loosing pto speed going down hill would pick up when level out. then no remote outlets work, then lost steering. brakes do work fine. hyd. oil level fine
How long since hyd filter was changed and sump screen cleaned? Have you tried hyd's with pto on & off or hyd hi-lo in both speeds? Does tractor have a FEL if so what type valve controls it. Look in hyd filler hole for spraying oil with engine running 3 pt raised up.
