48 A pulley tear down
E Needs
Finally got the pulley off the tractor. The bearing inside the pulley is bad and I need to get it out, however I can"t get the gear off the back of the pulley. I drove the key out toward the front of the pulley but the gear won"t come off. Any help is appreciated! Thanks!
Does that mean it needs to be pressed back on once it is removed? Sorry if this is a dumb question, but this is new to me. Thanks again!
Removing that gear won't help for a bearing.
The bearing ,washer,+dust shield just drives out from the backside thru the center hole with a long punch.
Thanks Mike, that helps a lot. What about the brass bushing, does it need to come out first to allow the bearing to come out? Thanks for all the help!
