JD 60 valve stem
jwuertz
I need an o-ring, or a complete stem.
Does anyone happen to have one?
Many thanks!
No luck with that yet, still looking.
Been to tire shops, parts stores, have not tried JD yet, but hopeful someone will haver one off an old JD
The one you need is what I refer to as "old style". I have one but the o-ring is bad on it as well. However, the stem size is the same as a new style stem, so buy a new style, use a pick and carefully remove the o-ring and install it on the stem you need to use. Another thought is to go to a hardware store or auto parts store and just buy an o-ring. Most will have a box with various sized o-rings. Good luck, Mike
Thanks, Mike.
Yes it maybe the original tube I believe, or close to it.
I haven't yet found the right o-ring, are they supposed to be flat? The rounds I have tried, stick out too far to slide in.
If you can find a hydraulic supply/rebuilder, the kind that can rebuild cylinders and valves, they should be able to fix you up. Good luck.
What you need is a # TR CH1 "tractor tire core housing". If you can"t find one at a local tire shop GOOGLE the # for sources.
Proud to say, I did find one complete with O-ring, but O-ring again, I dont understand why yet, but it was too big to go in the cylinder.
So, I wrapped some teflon tape around it, just enough where itwould slide in. Has not dropped
in pressure yet.
I will check out TSC also, and get another.
Thank you all for the good replies here, and the
guy who gave me the stem in West, Texas Goodyear
we have a whole box of them at work. and they are flat o rings, not the round ones like the new style cores
