Anonymous-0
Hello, I have a JD 60 (S/N 6046466) with live PTO. last year on occasion after stopping / switching gears, the tractor would not move again regardless of which gear I put it in. I could freely move shifter amongst all the gears with clutch engaged or disengaged - no movement, no grinding the gears, nothing. Its as if there is a intermittant "disconnect" between the pulley clutch and the transmisison, always brought on when shifting - not all the time but intermittingly. Tractor pulls great, no clutch slipping, then stop to change gears / direction and sometimes success (tractor moves per new gear shifted to), and sometimes tractor won't move in the chosen gear or any gear for that matter. fuss with it for a while, move shifter back and forth into and out of all the gears, shut off tractor, shift through all the gears, start back up, no improvement, etc. and then all of a sudden tractor would start moving again "business as usual" when clutch released. works great for awhile, sometimes even when changing gears / direction and then the next time randomly, same problem. tore clutch down, replaced suspect parts, same problem persists. Now its getting more frequent. Over the weekend the 60 was pulling my 7' drag offset JD Killiefer disk. started bogging down so pulled back on clutch lever (healthy snap to it per manual), shifted from 3rd to reverse, push clutch lever forward to back up tractor to close disk, and....engine lugged down briefly as pulley started turning then engine smoothed out as Deeres do, but tractor did not move. shifted multiple times between 1st and reverse and still no movement or grinding gears, etc. tried it several times over next hour, including putting tractor in and out of gears with clutch lever forward (Go) and back (stop)and even engine on / off) but still no movement. With clutch disengaged (lever fwd) and trans. in neutral, I could start to make the engine turn by hand turning the pulley. so this tells me clutch pack is grabbing the fiber disks and thus turning the crank. Tractor (Trans & clutch) works great until the next or several next times later of shifting gears and it then may or may not move the tractor. its killin' me. Suggestions?? Thanks so much!
