Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: '63 4010D trans/hyd pump broken bolts&damaged casting
Tim S
04-29-2013 09:06:02
I have seen the differential pin come out and smack the trans pump causing this,,take a close look at the pin and see if it"s in place...
Bob
04-29-2013 09:56:48
 Re: '63 4010D trans/hyd pump broken bolts&damaged casting in reply to Tim S, 04-29-2013 09:06:02
How about, some "BLEM" in the past had the tractor split and did not have the clutch splines/pilot shaft lined up and used a wrench on the bellhousing bolts? Is THAT possible?
About 15 years ago, a friend and I found a similar "wreck" in his 3010, had to get a $$$$ case from Pete Engen. We did NOT know it"s history, but figured that is what has happened in it"s past.
Tim S
04-29-2013 10:04:19
 Re: '63 4010D trans/hyd pump broken bolts&damaged casting in reply to Bob, 04-29-2013 09:56:48
Yes Bob that is a possibility also, it's never good to "pull" them together...
Tx Jim
04-29-2013 09:21:51
 Re: '63 4010D trans/hyd pump broken bolts&damaged castin in reply to Tim S, 04-29-2013 09:06:02
I agree with Tim to check diff pinion shafts.
