2030 3 point
I haven"t used my 2030 for a few years and need to this year. I never did get a diagnosis for what is going on with the 3 point. I do have the service manual but could use a bit of help.
There are times when it won"t lift when I move the 3 pt lever. Even if I move it several times. I know I can"t trust it when I get to the end of the field or I might have a mess. It seems to work sometimes and not others and it doesn"t seem to change whether it"s cold or warm. I have discovered that if I move the lever (for UP) and then immediately slightly touch the hydraulic lever, it will come up.
I"m guessing there"s a valve that could be sticking but don"t know exactly where to start. The John Deere mechanics here have no idea what"s wrong with it.
Anyone got any suggestions?
Thanks
Wes
When you state move 3 pt control lever then immediately touch hyd lever are you referring to the scv lever as hyd lever?? Have you or John Deere mechanics ever checked stand-by pressure?? With 3 pt lever in raised position,engine running look inside hyd filler hole for spraying oil. Where is L/D control lever setting(L or D)??
