1963 JD 4010 gas
Terry68
New User
I just purchased a 1963 JD 4010 and the PTO shaft will not engage, when I push the lever forward it feels as though there is no resistance at all. Does anyone have any ideas.
Take off the keyswitch panel and the belly plate under the flywheel housing and see whats moving and whats not. A helper would be useful. chris
Do as matthies suggested. It's possible the throw-in brg on the pressure plate ate the ends of the PP operating fingers off. Worse scenario would be if the 540/1000 rpm shift pins are broken
