620 Carb Assembly
shawmic
I"m replacing the 2 nozzles in the 620 carburator and they need to recess deep enough to put the nozzle plugs in? The nuzzles are very tight and I do not want to over-tork? Suggestions appreciated.
The nozzles should screw in easy and bottom out the gaskets.If they go in tight something is wrong with the threads. If the caps are touching the nozzle, they are not all the way in. Russ
