TractorLinks.com
Show Parts for Model:
Re: jd 4000 rockshaft control issue
JD Dave
04-27-2013 07:34:04
Thanks Jim & Tim. After tapping and spraying with Liquid Wrench the load control shaft will still only move a little and feels jammed in the "D" position. And you would think that if it's in the "D" position the rockshaft would work accordingly but it doesn't. From what I can read and see any adjustment will still not allow the arm to move. The bolts look like someone's had the valve off before. What do you think, - pull the rockshaft control valve and have a look?
Tim S
04-27-2013 08:02:24
 Re: jd 4000 rockshaft control issue in reply to JD Dave, 04-27-2013 07:34:04
If you kinda feel it hitting on some thing that's the next step, lift it off an look it over, there is a step-by-step sequence to re-adjust the hitch that will most likely need done...when your ready to do it I will try to post it for you...
