Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: jd 4000 rockshaft control issue
Tx Jim
04-27-2013 03:42:51
JD Dave
If you want to manually control the 3 pt then "D" is where the lever needs to be. Sounds to me as if L/D needs to be adjusted as outlined in the JD tech manual. One thing to check is operating valve clearances which is set by adjusting screw(parts key #2). This adjustment is outlined in tech manual and can be performed with housing on tractor. Also be sure the big nut(parts key# 15 or 24) is tight as they can loosen causing control problems
