Pie Weights JD
I took some pie weights off a 730 that had been used as front weights and they turned out to be JD pie weights. I figure they were used as weights for furrow wheels on maybe an old JD one-way or some kind of plow. They have a P700A cast in them and a JD. Thank you for any help.
Charlie
You are right, they were used on the furrow and rear wheels of disk tillers (one ways). There are 2 or 3 different shapes and weights depending on wheel and whether inside or outside of the wheel. I seem to recall some were 40 pounds per section and some about 28 or 30 lbs.
The Master Parts Index gives this info about P700A
Disk, Plow: 90, 100B, 120, 300, 400, M6-MT6
Tiller, Disk: Bantam, Heavy, Semi-Int,Small,
Standard
Lon
