TractorLinks.com
Show Parts for Model:
Re: B leaking gas from pulley.
Jake Winn
04-26-2013 16:01:10
Most likely the float in the carb has stuck, the needle stayed open and it filled the cylinders and crankcase with gas. Dont try and run it until you flush the system. It can and will ignite.
makin hay
04-26-2013 16:15:36
 Re: B leaking gas from pulley. in reply to Jake Winn, 04-26-2013 16:01:10
Are those quarter inch valves supposed to be open when its not in use??
makin hay
04-26-2013 16:10:19
Ok Thanks. But having red tractors all my life, i am wondering how on earth it filled the crankcase at the pulley? Is that a common housing with shared oil? On my IH M the pulley runs off the top of trans and has no continuity to the crankcase.
cooney minnie
04-26-2013 17:11:38
 Re: B leaking gas from pulley. in reply to makin hay, 04-26-2013 16:10:19
I'm not certain on B's, but on A's of that vintage, the cover the pulley is on - called the reduction gear cover- shares oil with the crankcase.
An operators manual will show you how to flush everything. As the above post stated, sounds like you have a stuck needle valve in the carb.
makin hay
04-26-2013 18:00:27
 Re: B leaking gas from pulley. in reply to cooney minnie, 04-26-2013 17:11:38
Thanks so much. I will start the hunt for a manual, big swap meet this weekend close by, hopefully I will find something.
buickanddeere
04-29-2013 04:56:41
 Re: B leaking gas from pulley. in reply to makin hay, 04-26-2013 18:00:27
1-800-522-7448
Lee B
04-26-2013 22:06:58
It's not so much a stuck needle valve in the carb, but the fact that someone left the gas on overnight. I know of no needle, and no carb that can stop a tankful of gas from getting into the engine when the gas is left on, while these same needles and carbs run just fine as long as the gas is shut off while the engine is off.
NOT really a problem, just shut off the gas and the problem goes away - and it happens to everybody at least once.
cooney minnie
04-26-2013 18:43:30
Remember, the B was wade from 1935-52, and there were a lot of changes. Look for a book that matches your tractor. Your area of concern, the reduction gear cover and lube, was one area that changed- or at least did on A's.
makin hay
04-27-2013 12:27:50
 Re: B leaking gas from pulley. in reply to cooney minnie, 04-26-2013 18:43:30
I cannot thank you all enough. I know to shut the gas off when engine off, do it on my IH's all the time. First green tractor I have ever owned!
The gas came out when I was loading it up on the trailer. I figure the auctioneers didnt shut gas off or whatever. Let it sit overnight and got over 2 1/2 gal of crappy black gas out of oil level petcock. Will drain entire crankcase overnight. THANKS!!!
clampdaddy
04-27-2013 13:36:49
 Re: B leaking gas from pulley. in reply to makin hay, 04-27-2013 12:27:50
If your tractor is an all fuel model you could probably drain the case, add another gallon or two of gasoline, and pour the black nasty mix back into the big fuel tank. :D
