520 steering spindle
jdman(MO)
520 rolled down hill hit tree, RM now pointing backwards. Pulled worm assy. steering gear and worm not broke. Are the stops in the gear, because pedestal will turn until it hits stops ,just 180 deg. out. It looks like the gear has stops in it. If I push the gear up should I be able to reposition the pedestal, then put hear back down?Russ
Does your tractor have power steering? If so the stops are 2 pins inside the steering cylinder that the vanes come up against. Those were sheered off and you'll have to disassemble to remove the broken pieces and fix the problem.
