TractorLinks.com
Show Parts for Model:
Re: JD B CARB
B-maniac
04-23-2013 11:07:55
That tracror carb combination should run wide open (no load) called fast idle with the load needle completely closed if all the passages are open. Matter of fact, that is how you set idle mixture. You are still plugged somewhere. I am assuming you have plenty of supply to carb and float is set sorrectly. If you know for a fact nothing is plugged then you have an air leak somewhere to the engine side of the carb.
ANDY E
04-24-2013 13:49:05
 Re: JD B CARB in reply to B-maniac, 04-23-2013 11:07:55
clean the jets again re-install carb works great now. thank for the information
