Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: 24 volt john deere
John T
04-23-2013 05:28:46
I know Jim at Agri Services and having seen his work, I just doubt his harness is wrong so I also have to go with somethings NOT wired right.
A while back our friend Tom 43 raised the 24 volt topic and Tx Jim there and several of us including yours truly covered it in great detail, you may wanna go back and review all that.
In order for the switch to best operate all the 12 volt POS grounded devices as well as 12 volt NEG grounded devices in cases where the two arent functioning is series (wouldnt require any frame ground connection at the batteries mid tie point) the A and B battery feeds up to it need to be in place and where the batteries tie together in the middle that point has a small jumper to the tractors frame ground, I agree with Jim, see if thats in place????????? if so then re check you have the correct harness for your tractor and the wiring just once more
Good luck, let us know what you find John T
buickanddeere
04-24-2013 06:36:47
 Re: 24 volt john deere in reply to John T, 04-23-2013 05:28:46
The wiring harnesses Jim sells at Agri Services for a modest price. Are of higher quality, superiour workmanship and container better instruction.than some electrical equipment I"ve seen approved for the Nuclear Industry.
Tx Jim
04-23-2013 06:07:21
John
When I stated wiring harness incorrect I mean't wrong harness for a particular serial number or installed incorrectly.
John T
04-23-2013 07:05:18
 Re: 24 volt john deere in reply to Tx Jim, 04-23-2013 06:07:21
I understand, I didnt give all the details, was in a hurry.....Knowing Jim I bet if he had the SN and the tractor wasnt modified the harness is correct!!
John T
Copyright © 1997-2015 Yesterday's Tractor Co.
