Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: 630 sticky valve when cold
gtx1967jewison
04-22-2013 17:44:20
please, before you rip open the engine, do a compression check when cold. If the valve is stuck youll have zero compression on that missing cylinder, or at least much less. also, start it up with the valve cover removed (youll have only a tiny oil loss) & at low idle you may be able to see it sticking. However, its much more likely you have an ignition issue, (try swapping wires & plugs to see if the opposite side misses) or even a lean condition on that barrell of the carburetor (something plugged).
good luck
