Rob Maloney
Well today we capped of the supply line and return line to the remote valves to try and isolate the problem causing slow 3 point lift. A funny thing happened--at first, after 10-12 cycles of the 3 point lift, lift time was about the same--about 7 seconds to lift the 3 point all the way to the top. Then I operated the loader, which forced priority to the 3 point lift, and after another 3 or 4 cycles the 3 point cycle time seemed about normal at just under 3 seconds. But, occasionally after driving and operating the tractor, cycle times will again be 6-7 seconds--almost like there may still be a slight leak somewhere. But, you might operate the 3 point 25 times in a row (with no other components of the tractor being used) and it cycle under 3 seconds. What does everybody think? SCV sound like the problem, and if do, why does the cycle time range from 3-7 seconds like it is depending on how the tractor is being used? Big thanks to all.
