70 lp standard
ben70b
search 70 lp standard on ebay and take a look at this oddball looking thing, to make it even worse someone put a single front wheel under the front end. looks kinda like odd to me.
Hi Ben,
Thanks for tip to the cool pic. Uncle Gene thinks his 70lp with the single front wheel is the finest looking JD in his fleet. It s all in the eye of the beholder. Are you bidding on this one? Good luck. VH
I love that thang! If I had 3000 to spare, I would"ve already bid on it! By the way, I noticed that the regulator/vaporizer looks like it has been customized, and no electric shutoff that I can see on the fuel strainer....how does it run? Hugh
Hi Hugh,
I don t know about the one on ebay, but Uncle Gene s was converted to gas by a previous and unknown owner. They used a two barrel DLTX but I don t remember the number. Maybe 71? As the compression on the LP is higher, he gets accused of cheating:) at the tractor pulls. The LP tank makes a good gas tank as the float guage works the same. Good luck on finding one. VH
