New to the 630
phess11
Driving a 630 around i noticed that the fuel gauge needle bounces around with the movement of the tractor. So is there no "buffer" to smooth the movement of the needle, or is this working as designed? thanks,
LOL I was thinking the same thing. You have one that moves? Yes, it will move with the movement of the fuel in the tank if it's an original gauge or one like it. Most of the original gauges quit working long ago so if it is indeed a factory one you should consider yourself fortunate. Some newer gauges have a dampening affect in the gauge to slow down the movement. Jim
