sweet corn planter recomendations
ben70b
i'm thinking of buying an old row planter to pull with the 60 or 70 and plant sweet corn and maybe popcorn, any suggestions?
290 pull type or 246 3pt. I"ve used both with great results. My 290 is adapted for a 3pt and may be for sale. I like the 246 better!!
Several years ago, I cut down a JD 80 planter to make a one row sweet corn planter out of it. It is a finger planter and will plant all size seeds. I use a one row planter so that I can plant 48" centers. It makes for EZ picking. Parts for the 80 are kind of hard to find; but, the internals of the 7000 are almost the same. You must cut out the inside disk to mach up with the old 80 disk.The fingers are the same. Keep it dry and keep it clean as they are prone to rotting out. Ed
