Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: 2640 3 point spraying at full lift
Tx Jim
04-17-2013 03:51:45
Does your tractor have a factory scv?? Here's you a parts list if the control valves are leaking.
T21641 GASKET ADD 14.59 USD
A4847R GASKET ADD 0.98 USD
F2741R PACKING ADD 2.90 USD
R26375 PACKING, -O- RING ADD 1.87 USD
R26448 PACKING, -O- RING ADD 1.46 USD
2-R31136 RING, BACK-UP ADD 1.01 USD 2.02 USD
T17882 RING,SEALING ADD 1.44 USD
2-R10093 PACKING ADD 0.88 USD 1.76 USD
R26286 PACKING,-O- RING ADD 1.30 USD
2-L55204 ORING ADD 1.09 USD 2.18 USD
total 30.50 USD
You should also check the valve(parts key #19) for wear.
This post was edited by Tx Jim at 03:54:32 04/17/13.
johndear720
04-22-2013 05:40:33
 Re: 2640 3 point spraying at full lift in reply to Tx Jim, 04-17-2013 03:51:45
Thanks for the parts list. Tractor does have factor SCV. I rebuilt it as it was leaking internal pretty bad. Had to leave it in float to keep implement from raising on its own. Bush hogging yesterday afternoon with heavy mower and lift quit working. Hydraulic pto worked as did steering. Was only running at 1500 rpm. Revving up engine got lift to raise. Apparently internal leak got much worse or priority valve, which has been rebuilt, malfunctioned. I'm guessing the heavy load has helped flesh out the leak. I may tear it apart this weekend to see if any hard parts are worn out and then order everything.
Copyright © 1997-2015 Yesterday's Tractor Co.
