1931 JD D ??
1936
Looking at one with a PTO is this a common item for the year?
Motor stuck from setting inside-has good paint and rebuilt carb. What would be a low end price on this??
A couple years ago I went to a small local farm sale that had a styled D on full steel with extensions. The tractor was stuck and all the sheet metal was dented up bad and the whole thing was solid rust.The tractor sold for 1500 dollars.It would of took a ton of money to restore it.Your being unstyled with PTO and good tin it should be worth alot more than that one.
