Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: 1970 JD 4320 weak hydraulics
Tim S
04-16-2013 18:13:56
First thing to do is check the stand by pressure by putting a gauge in one of the remotes and activating it, you should have 2250psi, if not you can turn the stroke valve screw in a couple turns on the under side of the pump till the pressure is right,,how do you have the loader plumbed in??
deerly parted
04-17-2013 17:57:53
 Re: 1970 JD 4320 weak hydraulics in reply to Tim S, 04-16-2013 18:13:56
The loader is plumbed directly into the rear hydraulic outlets and I use the console levers for control. No auxilary valve is used.
Tim S
04-17-2013 18:59:21
 Re: 1970 JD 4320 weak hydraulics in reply to deerly parted, 04-17-2013 17:57:53
This is not a good method to use...
