TractorLinks.com
Show Parts for Model:
Re: 730 D crankshaft
Rwolfejr
04-10-2013 05:29:03
That's right... Checked last night. The center main is spec'ed tighter because it's a thin multi layered bearing like in a car. Steel back then some sort of yellow metal then a thin layer of babbit. The .006 to 8 was for a 4" crank journal. If the 70 series have smaller journals they could be a breath tighter I suppose. The 830's took a thicker aluminum bearing and the center main is same clearance as the outers. The aluminum expands more than the cast iron and steel so you need to leave room for when it gets hot.
