Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: PTO noise in first reduction gear area.
Tyler-MO
04-10-2013 04:51:28
In my experience this gear rattling is something that occurs in the bevel gears on the PTO drive. I've had a few 720's that did the same thing. It was always worse when I turned to the right I think...but it might be to the left. The chattering sounds horrible, but I think it comes from when you're turning the maximum angles on the U-joints and it puts more feedback through the driveline. It's not a fun fix to say the least. You could remove the first reduction gear cover to check the play on the bevel gears, but to replace the bearings you would have to seperate the axle housing from the main case and perhaps even remove the transmission shafts. If you go in there be prepared to find all sorts of other things like chipped gears and tranny shaft bearings. Think $$$$
Best of Luck,
Tyler in IL
Nathan kapp
04-10-2013 07:08:16
 Re: PTO noise in first reduction gear area. in reply to Tyler-MO, 04-10-2013 04:51:28
Tyler, Thanks for the advice. It does sound like what you"re describing. Not audible when not under load; only when equipment is hooked to the Pto shaft. I"m preparing myself for an expensive bill- just wish I knew a good 2 cylinder mechanic in southeast pa. I"m thinking martins tractor.
Nate.
Tyler-MO
04-10-2013 07:58:05
 Re: PTO noise in first reduction gear area. in reply to Nathan kapp, 04-10-2013 07:08:16
The repair isn't something that requires a ton of technical know-how, just lots of dirty cothes, a few special tools and TIME & $$.
Nathan kapp
04-10-2013 10:58:04
 Re: PTO noise in first reduction gear area. in reply to Tyler-MO, 04-10-2013 07:58:05
Yea. I'm confident I could do the job. But time is what I'm short on...between getting married in 2 months and being a large animal vet.
