TractorLinks.com
Show Parts for Model:
Re: 1944 B Oil Return from Cylinder Head
al1933
04-08-2013 17:03:11
All the John Deere 2 cylinder tractor have an opening where yours is plugged that lets the oil travel thru the block back to crankcase.I know my 1952 G does.
Is that some kind of valve that when the valve cover is installed that is forced open and let oil return to crankcase?
jndrgreen
04-08-2013 18:27:07
 Re: 1944 B Oil Return from Cylinder Head in reply to al1933, 04-08-2013 17:03:11
No, it appears to be a stud. Should that stud be hollow? There is no valve there.
Or is the hole below the stud? I know I have looked at pictures of heads on ebay and they appear to have several holes near the bottom of th head.
My head appears to be filling all the way up to the push rod tubes before it drains back to the crank case.
gtx1967jewison@yahoo.com
04-09-2013 05:08:23
 Re: 1944 B Oil Return from Cylinder Head in reply to jndrgreen, 04-08-2013 18:27:07
That cant be the correct washer. Your head has a slot below the washer, but yours is covered.
04-09-2013 05:14:29
 Re: 1944 B Oil Return from Cylinder Head in reply to gtx1967jewison@yahoo.com, 04-09-2013 05:08:23
What is the serial # of your tractor? I have a parts book.
Jndrgreen
04-09-2013 05:34:46
 Re: 1944 B Oil Return from Cylinder Head in reply to gtx1967jewison@yahoo.com, 04-09-2013 05:14:29
167xxx
I can't ever remember the last 3 numbers.
Jndrgreen
04-09-2013 05:33:54
167xxx I can't ever remember the last four numbers. Its a 44 model.
Jndrgreen
04-09-2013 05:55:43
 Re: 1944 B Oil Return from Cylinder Head in reply to Jndrgreen, 04-09-2013 05:33:54
Can anyone tell me the torque spec for the head bolts? I am concerned to remove just one.
The book says 1150 in lb I think. Is this 96 ft lb? (1150 / 12)
Kent Petersen
04-09-2013 12:14:35
 Re: 1944 B Oil Return from Cylinder Head in reply to Jndrgreen, 04-09-2013 05:55:43
i can see by the picture that greenmeck has got it right you part # A4227R ihave one if you need want it $20.00 plus postage
