47 A, old clutch driver vs new
My old cracked clutch driver fitted onto the crank by lining up a a rivet on the driver with a flat spot on the crankshaft. The new replacement driver did not have the rivet but did have an etched arrow which I lined up with the flat spot and installed. There are no marks on the end of crankshaft so was this a correct installation?
Just match your old one up with the new one and see if the counter weighted area is in the same spot when matching up the vee mark and the dowel pin. I think they are ,but double check it.
